Results 1 to 10 of 27
Thread: Solar Cover and Reel Recommendations?
    duraleigh Guest
    Default
    Hi, Kay,
    If I read your post correctly, "that solar input would ever be greater than losses from evaporation." wouldn't that mean that a pools' temperature would never rise during the daytime? Mine sure does.
    As to whether the cover adds or subtracts from heat gain is, I think, dependent on all the other variables associated with the cover off (namely wind, RH, color of the pool, etc.)
    kaybinster Guest
    Default
    No, did not say that. Just stating that there is a huge loss of heat due to evaporation. I strongly believe that you are better off with the cover on as it reduces evaporative losses. I guess you could try it for a week with the cover on and a week with the cover off and (if conditions are the same) see which works better for you. I have done it both ways and find when I leave the cover on during the summer my heatpump almost never runs, but when I leave it off during the day the heatpump has to run more.
  1. Solar cover reel
    By Maacjones in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 01:05 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 01:45 PM
  3. what is the best Solar Cover Reel
    By Billybob in forum Pool Equipment & Operations
    Last Post: 08-15-2011, 10:43 PM
  4. Solar Cover Reel Recommendations
    By ToddLV in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2006, 03:40 PM
  5. Solar cover reel
    By Prov35 in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 12:07 PM
