Thread: leak at return fitting, Help
    Mar 2012
    Ohio
    Default leak at return fitting, Help
    Hi, I have a cracked eyeball fitting on the steps of my inground liner pool. The steps are white plastic and the plastic outlet fitting that is cracked appears to be mounted through a hole in the steps and an eyeball director threads into it. Can this be repaired from the front so I don't have to break up the concrete to get to the back? any help or ideas please. Thanks , Larry
    Default Re: leak at return fitting, Help
    Can you email pics of it to poolforum@gmail.com? Ben should be able to then post them to the forum and maybe that will help those trying to respond to you.
    Mar 2012
    Ohio
    I will take some photos but it may be a few days, thanks
    Welcome to the Forum!
    Please include some pics of the whole pool and the deck around the steps - it'll help us help you.
  1. How to replace return jet fitting
    By jrtredo in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2013, 11:18 PM
  2. Repaired Leaking Return Fitting w/o Draining Pool
    By eagle670 in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2012, 07:58 PM
  3. Leak around return
    By savdoc2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-30-2012, 02:07 PM
  4. 24 agp return leak
    By cvoytek in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2006, 11:13 AM
  5. wall return fitting
    By bethsg in forum Pool Equipment & Operations
    Last Post: 05-20-2006, 02:24 PM
