I use an in-line chlorine feeder with 3" trichlor pucks. I also use liquid chlorine which I buy in 3 gal carboys at the pool store. The primary concern with using trichlor pucks exclusively is the buildup of CYA during the season, and the higher it is the more chlorine you'll need to maintain a sanitized pool free of algae. In my case, I have a lot of splash-out requiring frequent additions of water. I once calculated that I probably replace 1/3 of my pool's volume each swim season. Hence, CYA buildup isn't a concern in my system.
At the beginning of the season there is no CYA in my pool. I normally close with CYA around 60.
When I first open the pool I add enough granular CYA to get to around 30 ppm. I also adjust FC, TA, and pH to the values I prefer. Then I run the in-line chlorinator at a setting of 1/4. This is where it gets tricky because the chlorinator only puts chems in your pool when the pump is running, of course. My pump is on for 6 hours out of 24 and I've learned that the 1/4 setting maintains the FC at around 3 ppm. If I ran the pump more, I'd get more chlorine, more CYA, and might experience a pH drop.
By the middle of the season I have all the CYA I need and turn the chlorinator off. That's when I go to strictly liquid chlorine, about 1.5 cups per day, depending on use. When I notice the FC dropping more than expected from use, I test for CYA and may add some. The chlorinator gets turned on again when we go on vacation or away for a long weekend.
So yes, they can be used successfully but I would not use it exclusively.
