Results 11 to 12 of 12
Thread: Particles coming out of the return valve
    Mar 2012
    Southern California
    Default Re: Particles coming out of the return valve
    I think I may have figured out the problem. Over the weekend, I took out (and apart) the filter grid. I found that 2 of the grids had tears in the bottom, so it cost me about $80 to replace them. Put it back together, turned on the filter, added DE, and crossed my fingers. No particles coming out of the return jets (so far).
    Quote Originally Posted by kramer840 View Post
    That would do it! Since you're not still leaking stuff, it sounds like you may not only have found "some" leaks, you found "the" leaks!
  1. Skimmer doesn't look active but I do see water coming in through the return
    By matthewxcarroll in forum Pool Equipment & Operations
    Last Post: 06-21-2013, 06:25 PM
  2. New to forum, bubbles coming from return jet
    By nilloc in forum --cleanup--
    Last Post: 06-19-2013, 10:20 PM
  3. Dirt coming in through the return
    By PoolOwnerT in forum Pool Equipment & Operations
    Last Post: 07-22-2011, 09:16 AM
  4. Air bubbles coming from return (from crack in pump pot)
    By AnnaK in forum Pool Equipment & Operations
    Last Post: 06-12-2007, 05:00 PM
