Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Hi please tell me how long to backwash ?
    Default Hi please tell me how long to backwash ?
    How long do I backwash ?
    Mandeville, LA, USA.
    Default Re: Hi please tell me how long to backwash ?
    Do you have a sight glass on the bachwash line (bubble looking thing)? If so, backwash until the water in the sight glass is clear. If not, backwash for about 2 minutes, go back to filter mode, check your pressure to see if it has returned to the "clean" level, and repeat as necessary (though 2 minutes of backwashing will usually suffice).
    Make sure that you shut down the pump each time before moving the handle on the multiport valve.
    Saint Cloud, FL
    Sierrasmom,
    We need to know some details of your pool setup, ie. pool size, pump size, filter, solar panels if any to answer that question.
    Pat
    27 round above ground pool 1.5 for the pump jacuzzi sand filter
    Hi Sierrasmom,
    it really doesn't matter how big/small or indifferent your pool is, whether your filter is black green red or blue, you backwash until your water coming out is clean/clear. Like Kurt mentioned, if you have a sight glass, it will tell you when to stop by the color (or lkack thereof)of the water, after stopping the pump, switch to rinse for about 10-20 seconds to clear out any debris still floating in the top of the filter.
    If you do not have a sightglass, look at what's coming out the end of the hose - same deal there.
    If your filter was extremely dirty, it may take 2 minutes or more to get it clean, if it was just somewhat dirty, a minute may do the job - see how pool size doesn't come into effect.
    ok thanks but someone asked how big my pool was and pump was .sorry i asked a question from now on i will just read and not ask ..i just need some questions answered we bought this pool from an individual it didnt come with anything i am just trying to get it clear so my daughter can enjoy it this summer ..
    Green Bay, WI
    My routine is switch to backwash, watch the sight glass and watch for clear water, usually about a minute, then rinse, then back to filter, shutting off the pump between any filter position changes.
    I have never really thought of this before but should you typically backwash in high speed on a two speed pump, would it matter, just take more time on low speed? I have always backwashed in high speed.
    West, Texas
    Sierrasmom,
    Keep asking questions, it is the best wau to learn. I dont think Matt was saying anything bad about your question he was just leting you know that the size of pool doesnt matter as far as backwashing. ( seeing how you were asked that question earlier) Sometimes on this here internet box it is hard to tell when someone is typing if they are being a smart ass or not and knowing the post Matt has posted before , he was not beng smart, and welcome to the pool learning center.
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
    diddo the pool idiot. Sierrasmom, Matt had the correct answer. He was not in any way putting you down for answering the question about size, ect. He would not do that. It is just that size does not matter. Your question was a good one, people new to pools need to know this.
    You may have more questions before you are a pool expert, we are all here to help.
    Later, Dennis
    ok thanks i have a filteration problem i think .i can backwash and i have good pressure and then there is hardly any pressure .i just dont understand what is wrong i believe this is my trouble ...thanks for all your help
  1. How often and how long do you backwash a sand filter
    By missparker205 in forum Pool Equipment & Operations
    Last Post: 06-04-2012, 02:17 PM
  2. Should I backwash??
    By newpoolguy in forum Pool Equipment & Operations
    Last Post: 07-25-2011, 09:59 AM
  3. How to backwash
    By allison in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-27-2006, 06:34 PM
  4. how do i backwash
    By dawny5 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2006, 10:42 AM
  5. How Long Is The Typical Backwash Cycle?
    By psbailey in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 09:28 AM
