My 2 cents about pH with 50 ppm borate and a SWCG. Don't drop the pH to 7.2. In fact, don't drop it lower than 7.6. It will tend to stay right around 7.7 for a long time. When it climbs above 7.8 it's time to drop it back down to 7.6. Make sure you keep your TA at 70 ppm (and bring up the CH if you have a plaster or fiberglass pool to keep the water balanced) and keep the CYA at the manfuacturers recommended max. (usually 80 or 100 ppm).
BTW, even with an acid demand test you really have no way of knowing just how high above 8.0 your pH has risen because the amount of buffer (bicarbonate and borare) in the water will have an effect on the demand tests. All you really know is that the pH is 8.0 or above. If you want to know how much above you would need a different pH indicator solution that tests a higher pH range.
