Hi bigdog, and welcome to the forum!!
I can't answer all of your questions, but I can contribute toward a couple of them, and I'm sure someone will be along shortly to answer the rest.
Regarding salt vs. chlorine--they're the same thing! When you have a salt pool, the SWG takes that salt in the water and generates the chlorine for the pool. So--it's still a chlorine pool, the only difference is that with the salt pool the chlorine is being generated in the pool itself, and with a standard chlorine pool, you have to add it manually. So...either way there will be byproducts, but what byproducts you mean will depend on the chlorination method. Using bleach, or pool chlorine, your byproducts are water, chlorine, and salt. With Cal hypo, it's chlorine and calcium. With dichlor or trichlor, it's chlorine, acid, and stabilizer.. So...with a SWCG, you do have to keep an eye on your pH, and adjust it periodically, but otherwise the pool is pretty much maintenance free once you get things balanced. With manually added chlorine, you have to make sure your chlorine levels don't get too low, and have to keep a closer eye on your other parameters, depending on which form of chlorine you're using.
The ultraviolet system isn't going to do anything about your pH, calcium, or acid levels, if you're considering those to be the chlorine byproducts. UV light will disinfect the water, but onlythe water within the unit itself--once the water leaves the unit and goes into the pool, you're still going to have to have a chlorine residual to keep the water clean enough to swim in. So in most cases, you're wasting your money on the UV unit--I personally would leave that out and spend the money on a good SWCG system.
