With a cya reading of over 100, running a chlorine reading of 1.0 will give you your green pool back in no time. See the chart at the following link for more about chlorine levels and cya levels.
http://www.poolforum.com/pf2/showthread.php?t=365
Cya over 100 could be a lot of numbers. We really need a more exact reading. We typically suggest a cya reading of 30-50. You can do a partial drain and lower it. Don't drain the whole pool. You may have to do a partial drain a couple of times to get the cya down. Your other option is to keep your high cya level and just run higher than normal chlorine levels per the chart. I would suggest buying the kit sold at the sister site to this forum www.poolsolutions.com as it will allow you to test chlorine readings to 50 plus everything else you need to test. Hope this helps.
