Hi all, New member and 1st post. I set up my 1st pool 2 weeks ago. 18x4 steel frame AG. I filled it with well water as it's free and it's a deep well. I live in Florida. Everything seems to be fine right now except for a high TA, about 290. When the pool was filled the PH was 6.8 and I added PH plus and now it's 7.6. Been stable at 7.6 for over a week.
I assume the well water is the reason for the high TA?
If my PH has been stable should I worry about the hight TA?
To replace evaporated water, would you recommend I use the well water or city potable water which BTW has cloramine in it. I assume the cloramine is not good for the pool but neither is the well water if it's the reason for the high TA.
Should I add water using well or city?
I'm glad I found this site. I've learned alot reading everything and the people here seem so nice.
