How long should a pool run to obtain an accurate reading on chemical test? The current water temperature is averaging 52 degrees and my timers are set to run from midnight to 5am. Assuming the pool has been off and not circulating for 5 or 6 hours how long does it need to run for truly accurate readings and how much does the lower temperature affect the accuracy of the readings?
Steve (currently working as a pool cleaner)..
