Thread: The perfect test
    .warren, michigan
    Unhappy The perfect test
    I have a 24K IG guinte w/plaster pool. What would be the perfect test results for each catagory using the ps234?
    Default Re: The perfect test
    "Perfect" is going to vary by pool, but some general guidelines would be pH 7.2-7.8, TA 80-120, CH 200-400, Cl minimim of 3 ppm but will need to be higher depending on your CYA level (see Ben's best guess chart in the Chlorine section). Beginning target CYA is debatable, but most around the forum recommend 20-40.
    .warren, michigan
    Wink Re: The perfect test
    Thanks Aylad! That's a good way to start. Looking foward to a great swimming season (if it ever stops raining!!).
  1. Clear but not perfect - yet.
    By mwoolfso in forum --cleanup--
    Last Post: 06-09-2013, 05:52 PM
  2. Perfect Pool Problems???
    By KPalom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2011, 09:01 PM
  3. The Perfect Storm
    By janmo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-17-2007, 12:38 PM
  4. Does perfect CL levels mean no irritation to eyes?
    By rastoma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-19-2006, 09:41 AM
  5. What are the Perfect Numbers?
    By Aranon in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-25-2006, 10:42 PM
