Results 1 to 10 of 13
Thread: how to lower water level using pool pump
    Default Re: how to lower water level using pool pump
    Hi John!
    Has the water in the pool risen again or did it stay down?
    Aug 2011
    Martinez CA in San Francisco Bay Area
    I just took a look. It's been 48 hours since I lowered it. I would say the level has stayed the same. The spillover between my spa and pool is a bit wet but that's probably because we've had very high winds the last 24 hours or so. The water level is still just below the spillover, which is where I set it. If it starts creeping up, any guesses as to the cause?
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    I guess it comes down to:
    1) Rain
    2) Spillover
    3) something leaking between them
    4) something else leaking into the pool
    I don't see any other possibilities. 3) and 4) would probably imply a valve or cut-off leaking.
    Aug 2011
    OK, thanks Carl. Since it hasn't rained here in six weeks, I'll focus on 2) through 4). I will keep a close watch on it from here on. If it keeps recurring, sounds like I'll have to do some leak detection (i.e., digging). Thanks for the suggestions.
    - John
    John
    Apr 2011
    I added a draing to my Clean and Clear filter, its easy, Maybe 30 in parts. Cheaper and easier than a sump pump.
    http://www.troublefreepool.com/addin...ng-t35088.html
    17K IGP, CSPC 48, Pentair CC100 Cartridge filter, 1HP DuraGlas II,
    Aug 2011
    thanks for passing that thread along. If I feel adventurous, I may give it a try.
    John
  1. Appropriate Water Level for Unlevel Pool
    By jachol in forum Intex-type Pool Setup & Operations
    Last Post: 06-02-2013, 05:43 PM
  2. New Saltwater Pool---How to lower the water level with autofill?
    By AmHistoryNut in forum Pool Equipment & Operations
    Last Post: 03-11-2012, 02:17 PM
  3. Newly converted...how do I lower combined chlorine level?
    By tmess13 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-17-2006, 08:19 AM
  4. water level in pool
    By tara15 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-12-2006, 03:20 PM
  5. Bilge pump to keep water level below tiles
    By MarkC in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2006, 02:54 PM
