Thread: Need an idea for washing a leaf net
    Duanesburg, NY
    Default Need an idea for washing a leaf net
    Pulled the net off our pool this weekend (finally!). It did a great job as we have two maples near the pool and it would've taken a lot longer to scoop the offenders off a solid cover or out of the water. Wrapped it all up and dragged it out to the back of the back yard and dumped 'em.
    Now, what to do with the net? It's pretty well coated with leaf remnants, algae and who-knows-what-other biomass. I spread it out on the lawn and am contemplating running it thru the laundry. I'd probably fold it into eighths and hang it over our 6' high fence for a hosing off first. I'm not sure of the weight but it's just big enough to cover our 17x33 inground.
    Anyone have any other ideas?
    C.
    mbar's Avatar
    Ashland, PA
    Default Re: Need an idea for washing a leaf net
    I would take it to a laundromat and run it through a wash cycle, without using any soap. You can put some bleach in the water. If you don't want to do that, I would just hose it off and hang it up to dry in the sun. Don't put it away wet. Just my thoughts!, but I would take the easier way of not lugging the net back and forth to the laundry.
    Northeast PA
    Canada.
    I just took my 27' AG leaf net off this weekend. I spread it out on our lawn and took a pressure washer to it! It worked great as I had alot of scum on it from the leaves sitting on it over the winter. The pressure washer just sprayed all that stuff off with ease! Let it dry in the sun and folded it up!
    Orlando, FL
    How about soaking in a garbage can with a bunch of bleach. You dump bleach into pools to clean them of algae and other junk, why not the net!! Then I'd pressure wash and let dry.
    Duanesburg, NY
    Great ideas, all.
    Thanks much!
    C.
  1. borax vs Arm and Hammer washing soda
    By joecus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2010, 02:10 PM
  2. Underwater Pressure Washing Gunite Pool
    By dbbarron in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2010, 02:56 PM
  3. Leaf net cover
    By Macrosill in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-11-2006, 08:55 PM
  4. Draining and acid washing to get rid of black algae
    By howbout in forum Dealing with Algae & Slime
    Last Post: 05-20-2006, 10:47 AM
  5. Power Washing an IG Pool???
    By wetshoes1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-12-2006, 10:06 AM
