Results 1 to 8 of 8
Thread: Electrical Questions
    Oct 2011
    Default Electrical Questions
    My new pool is almost finished and I have been looking at the electrical and have some questions. The pool guy will be here later today but I would like some more thoughts.
    They installed a 220v breaker in my main box inside and ran it out to another box by the pump/filter. In the outside box is a 110v gfi breaker for the light, a 110v breaker running to a gfi outlet, and another 220v breaker for the pump. I don't see how the pump is protected with a gfi, am I right in thinking it should absolutely have one? There is also no on/off switch for the pump that I see, since the 220v breaker is open now, it looks like that is how they plan to turn it on/off. I also think this is bad practice.
    I'm going to discuss this later today with the pool people but I would like some more opinions.
    Oct 2011
    Default Re: Electrical Questions
    I'm here to read and learn myself, but that doesn't sound like the most efficient/practical way to operate the pump. How difficult was the filter set-up?
    It's pretty common to use a local breaker as a pump on/off switch. A heavy duty motor-rated toggle switch (like a light switch) will cost more than a breaker.
    It is not common to put an in-ground pool pump on a GFCI . . . and I wouldn't want to do so. If the pool is bonded properly (and grounded -- which is a distinct but related thing), there's no hazard. The key here is to make sure the pool is installed to code AND is inspected.
    Oct 2011
    They are going to add a switch and gfci breaker. I agree the switch is probably not necessary. They also do not think code requires a gfci on the pool pump, but after some googling this I found that in 2008 NEC 680.22b now requires all pump motors to have gfci protection. Can you take a look at that and see if you would agree? Is there any reason not to want this?
    My concrete is suppose to be done next week, I really don't expect to see them do any bonding of the rebar, diving board jig, handrails, coping, or anything. Should I insist on this? I expect to get the "we install pools all the time and never do that" answer.
    BigDave's Avatar
    Jul 2010
    New Jersey
    Check with your local electrical inspector, each municipality adopts the NEC at different times and many are several years behind. Many municipalities also ammend the NEC. In my area, GFCI is required for circulation as is a twist lock outlet and cord not more than 3' long although none of this is specified in the locally adopted version of NEC.
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    Quote Originally Posted by BigDave View Post
    Yup, that's code in New Jersey suburbs--I have the same codes as Big Dave, including the twist-lock, 3' cord, AND internal timer! Oh, and ANYTHING outdoors, or near water in NJ must have GFCI. No exceptions.
    vinper is offline Subscriber Thread Analyst vinper 0
    Jul 2010
    Texas
    The main breaker to my whole 60 amp sub panel is a ground fault breaker . So everything on the panel is protected and you dont need gfci recepticle... By using a main gfci breaker its cheaper than using all seperate ones.
  1. Filter pump cord length and some other electrical questions?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-20-2007, 10:38 AM
  2. Dolphin set-up & electrical questions
    By RavenNS in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-16-2006, 01:43 AM
  3. Electrical for pool
    By us7sail in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 02:49 PM
  4. Electrical schematics for SWG ???
    By mrmrk49 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-22-2006, 11:31 PM
  5. Electrical SWG
    By Jeffery in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-05-2006, 06:21 PM
