Thread: High Calcium
    Default High Calcium
    Hi everyone,
    My calcium number now has hit 500, and I've noticed that I had to clean my cell more often on my SWG. When the value was around 300-350, I had to clean it every 5-6 weeks. Now it can't even go 2 weeks without build up.
    I have plaster pool with pebble tech finish. Water is crystal clear. Size about 13,000 gallons.
    PH: 7.2 (was almost 8 yesterday)
    CC: 0
    TA: 80
    CH: 500
    CYA: 70
    I've noticed that they now sell a product that can remove calcium without draining part of the water out. Do those work at all?
    On draining the pool, is there a calculation that can be used to determine how much water to remove to bring it back down to the 300 level?
    I'm concerned about the high level since I have a SWG pool with a cell and a heater.
    Default Re: High Calcium
    I don't know about calcium removers but if your fill water has 0 calcium, drain off 20% and refill and you should be around 300ppm. If your fill water has calcium, you'll have to do some simple arithmetic. Supposing your fill water is 100ppm. Drain off 1/2 of 500ppm and refill with 100ppm. You should get 300ppm.
    You may also be able to improve your results by simply lowering your t/a further.
  1. high calcium
    By alisonquilts in forum Dealing with Alkalinity and Calcium
    Last Post: 06-10-2012, 08:03 PM
  2. Very high calcium and TA
    By smokeygrl in forum Dealing with Alkalinity and Calcium
    Last Post: 05-24-2008, 11:56 PM
  3. High Calcium
    By Chance in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2007, 12:25 PM
  4. Is high calcium bad for SWG?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2006, 11:17 PM
  5. HIGH Calcium
    By derrikm in forum Dealing with Alkalinity and Calcium
    Last Post: 06-01-2006, 12:29 AM
