Thread: 2 speed pump trips breaker
    BigDave's Avatar
    Default Re: 2 speed pump trips breaker
    Electrical theory and the trade practice of Electricians are different and often not mutually understood. Power Systems Engineers should understand that unbalanced loads and neutral faults and opens (in the customer premises as well as the mains and distribution networks) can cause unexpected voltages on neutral and lines. Neutral should be connected to Ground at the service entrance panel so voltage on the power company neutral could be seen on the Ground line.
    I'd want to know what the line to line and line to ground voltages are on this circuit with the control system disconnected.
    Bottom line - something's wrong. A good Electrician with pool experience should be able to help.
  1. Pump popping breaker.
    By 737Mech in forum Pool Equipment & Operations
    Last Post: 06-13-2012, 11:38 PM
  2. New Whisperflo Trips Breaker
    By jzerf in forum Pool Equipment & Operations
    Last Post: 07-27-2008, 09:59 AM
  3. 2 Spd pump trips breaker in high spd only
    By posguy in forum Pool Equipment & Operations
    Last Post: 06-07-2006, 07:56 PM
  4. GFI Breaker trips when I use the outlet
    By RENOPOOL in forum Pool Equipment & Operations
    Last Post: 05-23-2006, 08:49 PM
  5. pump trips ground fault breaker..
    By turnerd in forum Pool Equipment & Operations
    Last Post: 05-23-2006, 01:42 PM
