Results 1 to 10 of 24
Thread: Replacing water to get rid of CYA
    Default Re: Replacing water to get rid of CYA
    Quote Originally Posted by Poconos
    I'm thinking of the vacuum hose setup that hooks to the skimmer. Should be able to hook it as you would for vacuuming but set the valve to waste and leave the hose in the deep end of the pool.
    Can't vacumn to waste with a cartridge filter. I had to partially drain and refill my pool when they set up the SWG because they dumped in too much salt and my cell shut off with a high salt warning. I used a submersable aquarium pump (a very large one) and drained a foot below the skimmer. I then refilled and had to repeat this 3 times to get my salt levels in line. It is not necessary to drain all at once. You can drain a foot and refill until the CYA levels are where you want them.
    makodav is offline ** No working email address ** makodav 0
    Unless your pool is sitting way low you should at least be able to get a gravity flow drain going using a couple garden hoses. Run the water from the garden hose into the pool and run another garden hose out the pool. Get a flow going into the hose leaving the pool for 20 seconds and then the flow should continue. Also you can always use your filter pump but not through your usual vacuum setup through the skimmer. If you submerge the hose that usually goes to the skimmer under water you can pump water out of your pool for ever with your return line going to where you want to drain!
  1. Replacing liner with high water table
    By jjdean in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2011, 07:14 PM
  2. Replacing SWG
    By bruceanast in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-31-2010, 04:06 PM
  3. Replacing old SWG
    By joepa300 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-07-2008, 07:47 PM
  4. Emptying water before replacing liner
    By CathyOh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 12:18 AM
  5. Replacing liner and water
    By brider18 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-20-2006, 04:21 PM
