Results 1 to 10 of 14
Thread: Big CL Demand/CYA Process time?
    Default Re: Big CL Demand/CYA Process time?
    I'm using an OTO Walmart kit, picked up Ben's few days ago (awaiting) & will post soon
    pool was opened in late April .....CYA was normal as far as I remember last year , around 50
    pool looks a bit cloudy...algae cometh....& I'm buying bleach like the wash boy for the SF 49ers
    dumped in a bunch tonight & later reading was 2PPM....seems very difficult to not let the level "yo yo" as Watermom puts it.....
    thanks!
    You are right, it is difficult, but that is the key to killing algae. That is why we say test 3x a day and each time shock it back up. Actually, you can test/shock more than 3x a day if you have time.
    Quote Originally Posted by h20man
    thanks!
    If you closed to 50 ppm CYA and opened to 7 ppm then you probably have a lot of ammonia compounds in your pool from the biodegration of the CYA. This is part of the reason for you huge chlorine demand. The algae is possibly the second part. Until all the stuff that is consuming the chlorine is gone you just have to keep putting in more until it start to hold. Just have patience and have a lot of bleach on hand and it will eventually burn it all off, kill the algae, and you will be swimming soon. Watermom has given you sound advice! Try to follow it as best you can.
    I'm a drummer , not a chemist !! well....a part time pool guy now....thanks 4 all the advice, I'm on it... I've never seen a pool eat CL like this...just dumped in 2 gallons of 12.5% CL & did a test 45 mins later & 1ppm!!!
    CYA is up 22 now
    It's going to be eating chlorine until the chlorine demand is statified. Sorry if I got too technical before but I was trying to explain that there IS a reason why your pool is temporarily 'eating chlorine'. It's very hungry for it right now! Just be assured that if you keep following the good advice you've been given so far and have a little patience and a LOT of bleach your pool will soon be back to normal.
  1. huge clorine demand
    By sabres07 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2013, 02:22 PM
  2. Chlorine Demand
    By gfritz1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2012, 10:26 PM
  3. What is the BBB process?
    By Mousefan71 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2011, 07:21 PM
  4. not sure pf process
    By brandi in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-13-2006, 08:12 PM
  5. Chlorine Demand
    By bmgo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-02-2006, 10:53 AM
