Results 1 to 10 of 32
Thread: Weird teeny tiny bugs and stinging/flying ant things
    Default Re: Weird teeny tiny bugs and stinging/flying ant things
    Do they appear to live at the waterline and jump back and forth from the water to the edge of the pool? If so, they're springtails--when I get them, I shock the $#@@ out of the pool and they go away.
    Houston.
    Hi Janet.
    Yes, they do seem to jump back and forth. A lot of them were floating on the water, but there were a lot on the tile also. When I scooped some up in a cup, I did notice that some would jump from the side to the water and back and forth.
    It sounds like these are springtails. I just saw cpmart's post "springtails or water fleas" and saw your post in there too. I put in 3 gallons of bleach 6% earlier today. In my 20000 gal pool, that should give me 9+ 3 I already had in there. I'll go get some more and get up to 15 per Ben's best guess chart.
    Do you keep it there, or did it seem to kill them instantly and you could let it drift back to normal right away?
    Thanks,
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    let it drift back to normal, by the time it does tehy will be dead at 15ppm.
  1. tiny black larvae or leach like bugs
    By triciajeanine in forum Pools, Pets and Creepy Critters
    Last Post: 06-26-2013, 04:23 PM
  2. Yuck! Tiny bugs all over the outside of our pool
    By blessedbeingmom in forum Pools, Pets and Creepy Critters
    Last Post: 07-02-2010, 11:24 PM
  3. Clouds of tiny bugs on water surface
    By TX78539 in forum Pools, Pets and Creepy Critters
    Last Post: 08-30-2007, 10:30 AM
  4. Common causes of eye stinging
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2006, 11:44 AM
