Results 1 to 10 of 32
Thread: Weird teeny tiny bugs and stinging/flying ant things
    Houston.
    Default Re: Weird teeny tiny bugs and stinging/flying ant things
    Janet,
    What is a cloth splash ball? Your idea makes sense because they do tend to climb onto any float that's in the pool?
    Thanks,
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    They're sold in the pool toys section at WalMart or most anyplace that sells pool toys, usually in packs of 3 or 4--they're just balls made of cloth, about tennis-ball sized, that you put in the water and it soaks water up, like a sponge, then your kids throw them at each other--sort of like cloth water balloons. But it doesn't have to be those--you can float a couple of tennis balls, or a nerf ball, or anything else that will float and is small enough for you to cover in ant spray before they all crawl off.
    Houston.
    Thanks Janet. I know what you're talking about now. In fact, we may already have some of those.
    Robert
    Sanford, FL
    I know they are expensive - but what about a screened pool enclosure? We would never be able to go out from dusk to dawn without one here in FL. You'll get 2-3 mosquito bites just running from the car to the house on a bad day.
    Those worm things - they must crawl across the dirt to get to your pool? Have you tried some sort of residual bug killer around the pool so when they crawl over it they die BEFORE they make it to the pool?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Houston TX
    We also get the flying ants in the Houston area, especially after rain. (No sign of the wormy things, though... ) I just take my trusty net skimmer thingy and scoop them all off before getting into the pool.
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    I suspect the stinging flying ants are a variety of fire ants. The red ones we've got are imported. Yours may or may not be local. Your local university extension office probably has some kind of recommended way of killing them. It's a big deal down here, Texas A&M actually has this;
    http://fireant.tamu.edu/
    Look for specific instructions on when to put down the broadcast baits and you'll probably do as well on your own as an exterminator.
    As far as the wormies I've got no idea. Do you use polyquat in your pool? I've noticed that some bugs seem to die faster since I added it. I figure it's because the polyquat acts like a surfacant and "drowns" them the way watered down dish soap kills bees.
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Houston.
    Ugh! I've got those little brown worm things now. I noticed them in the skimmer a while ago, but I thought it was dust that wasn't sinking. I just saw them in the water by the step and picked some up in a cup. I'll post a picture shortly, but needless to say, I almost gagged to see that the dust was moving. They are little worm like things. I mean little, but there are bunches of them. Too small to pick up with net.
    Robert
    Jul 2006
    Rosemount, MN
    Unhappy Re: Weird teeny tiny bugs and stinging/flying ant things
    I have those wormy things in my pool and am disgusted by them. Mine don't seem to be on the top of the water. They seem to be more on the bottom and only towards the top when the pool is stirred up from someone being in there. I noticed them when vacuuming the pool. There were TONS of them in the bag. They are tan in color, almost looks like bleached out grass seed. They look just like that picture that's posted. Most of them were not moving, but at a really close look a few of them were. I shocked the pool yesterday and now it is raining today, so we will see how many are there when I am able to vacuum again. I really would like to know what they are. Who wants to swim in a worm pool?
    Jul 2006
    I was having a problem with round black bugs about 2 cm across and also those tiny bugs you are talking about and I have cut down a small tree that was to the side of the pool and I moved my security light to another location. The security light was right next to pool. I was proud of the security light there for swimming at night but I did not anticipate the bug problem. I hope this helps you.
  1. tiny black larvae or leach like bugs
    By triciajeanine in forum Pools, Pets and Creepy Critters
    Last Post: 06-26-2013, 04:23 PM
  2. Yuck! Tiny bugs all over the outside of our pool
    By blessedbeingmom in forum Pools, Pets and Creepy Critters
    Last Post: 07-02-2010, 11:24 PM
  3. Clouds of tiny bugs on water surface
    By TX78539 in forum Pools, Pets and Creepy Critters
    Last Post: 08-30-2007, 10:30 AM
  4. Common causes of eye stinging
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2006, 11:44 AM
