Results 1 to 10 of 14
Thread: My First post - high salt?
    Houston.
    Default Re: My First post - high salt?
    Quote Originally Posted by jonnymac View Post
    Over the past year, the stone has begun to degrade again. The stone guy told me the best method to apply the products was to literally soak each stone in it before installation. For now, I just shop-vac the coping/deck occasionally and the cleaner picks up the stuff that falls in the pool.
    Getting 4-5 years of help is good. Do you think it would help to use the drytreat again?
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    Aug 2011
    Southeast Texas
    Quote Originally Posted by rpoldervaart View Post
    Yes, I think I would probably get at least the same results. The applicator said the DryTreat was actually pushing the old sealer out of the rock as it soaked in, so since the rock has had no treatment since then, it may be even better second time around. At that time, DryTreat had more than one product for the same fix (one was applied, then another, etc.) Note: Some of it will get in the water causing moderate foaming, maybe some cloudiness, etc. In my case, the stone had to be hosed down several times as the old stuff came out of the rock surface. It cleaned up fine after a few days.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. First post, I have a high pressure reading 35psi
    By bri3180 in forum Pool Equipment & Operations
    Last Post: 10-03-2011, 07:57 PM
  3. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  4. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
