In the water, given a fixed CYA, one form of chlorine is no more or less susceptible to the sun than another. They all are.
Some powdered chlorine (dichlor) contains stabilizer and will increase your CYA level (increasing your sun protection and your required FC level for shock and normal operation). Dichlor will also lower your pH.
You reported a pH of 7.1 on 8/29; this is near the bottom of the scale, my K-2006 pH scale only goes to 7.0 in 0.2 increments, was the color between 7.0 and 7.2? If your pH is still that low (or lower if you're using dichlor), I'd recommend that you add some Borax to bring it up to the 7.4-7.6 range. Start with a couple cups, give it time to dissolve and circulate and test again. Add more if needed.
Are you still using trichlor? Trichlor will also drop your pH.
The other widely available powdered chlorine source is Calcium Hypochlorite which is just like bleach (and liquid chlorine - same thing as bleach) when it comes to the sun.
