The salt test from the PS234 has to be the one you use to calibrate the Aqualogic's setting. Once you drain down and refill, check with the PS234 again, and if you have less than 4000 ppm, set the Aqualogic to the salt test value you got.
The Aqualogic is set to a default reading until checked against a salt test, and then you adjust the Aqualogic accordingly.
Hope this helps.
Pat
