Thread: slightly green slightly cloudy
    jupitersen Guest
    Default slightly green slightly cloudy
    hi, i'm trying to understand why our pool water is so prone to becoming slightly green and cloudy. the ph is at 7.2, the free chlorine at above or about 10, due to recent shock treatment non stablised chlorine; total alkalinity around 140 and stabilizer ppm about 100-150, fairly high. The filtration system is a hayward cartridge system and the pool holds about 55 cubic meters. I am beginning to suspect that the filtration rate is not adequate but the installer says it is in line with parameters. I'm beginning to think I need to put in a sand filtration system and pump. Does anyone have any suggestions to why we have continuing problems? I 'd appreciate any suggestions. Thanks
    Default Re: slighlty green slightly cloudy
    I think it is because your chlorine level is too low for such a high CYA (stabilizer) pool. Take a look at the Best Guess Chlorine chart in my signature below.
    Welcome to the Pool Forum!
    Jupiter, if you have sodium hypochlorite laundry bleach available there, and can tell us the active %, we can tell you how to use it to clear up the algae.
    Ben
  1. Slightly cloudy with brown residue at the bottom
    By proximo in forum Dealing with Algae & Slime
    Last Post: 07-12-2013, 11:22 AM
  2. After 2" heavy rain shower pool water is slightly cloudy
    By silvergalore in forum --cleanup--
    Last Post: 06-28-2013, 09:29 PM
  3. Conflicting Advice and a slightly cloudy pool
    By MVB621 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-02-2010, 11:21 PM
  4. Slightly Cloudy Water after Opening
    By njpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-04-2007, 09:19 PM
  5. Slightly Cloudy
    By Rmadara in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-30-2006, 04:59 PM
