Thread: Buying a New Pump
    Honesdale PA
    Default Re: Buying a New Pump
    First question is about the present wiring. 120 or 240 volts? That S200 filter is rated at 44 GPM so you want to stay under that. The Hayward site leaves a lot to be desired for getting detailed info on a specific pump but on a quick look I'm thinking of a 1/2 HP full rated, something like the SP2600X5 single speed so you are right on your thinking about the 1/2 HP. Then we get into the two speed pumps for more $$$. As for wiring the thing in, that's easy if you stay with the same voltage but if you change then things get more complicated. I think that model I mentioned is what Watermom has for her AG pool and the suction for vacuuming is quite adequate. I've got a 1 HP Superpump for my 22K IG and it's 14 years old and still going strong.
    I have 1hp superpump 2 spd for my 19,000 gallon pool and it's fine after 9 years. But I have a 200# sand filter which is close to its maximum when the pump is on "HIGH".
    Jun 2011
    Franklin, TN
    Thanks for all the info guys. I'm gonna try to limp along fot the rest of this season, do some more research over the winter and plan to put in a new pump when I reopen next spring. I'll share my plans with ya'll in a few months and see what you think.
    Pool Specs: 20,000 gal. • inground • vinyl liner • Hayward s200 sand filter
    21' kidney 20K gal AG pool; Bleach; Hayward S200 sand filter; Hayward pump; 8/10/2012hrs; Taylor k2600; utility water; summer: ; winter: ; iPhone; PF:6
  1. Help - buying used AG Pool
    By lancemwilliams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2013, 12:47 AM
  2. Buying Guide
    By FiveStarPapa in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2013, 10:43 PM
  3. Buying natural gas htr for AGP.
    By tnt69 in forum Pool Equipment & Operations
    Last Post: 09-28-2011, 06:08 PM
  4. buying new pool
    By happyjack in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2010, 03:26 PM
  5. Buying New Pump - Need Advice on Brand / Size etc.
    By Gwendolyn in forum Above-Ground Pool Construction & Repair
    Last Post: 04-09-2006, 01:00 PM
