Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Odds-n-Ends (P)
The China Shop
Safe pH levels for vinyl pools
FAQ
register
Results 1 to 10 of 29
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
07-24-2011
07:39 PM
#4
SalemCastles
Guest
Re: Sudden cloudiness
Yes that's what I was thinking ... if it ain't broken don't try to fix it.
Quick Navigation
The China Shop
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
New China Shop Topic: How Accurate is the Pool Calculator?
Salt Level Keeps High without Addition of Any Salt
Safe to swim Chlorine levels
By sabres07 in forum Using Chlorine and Chlorinating Chemicals
1
Last Post:
08-01-2012,
05:50 PM
Is wheeled vac like Pentair ProVac/Commercial Vac safe for vinyl/ABG pools?
By Rakfiddad in forum Pool Cleaning: Manual or Automatic
0
Last Post:
06-14-2012,
12:42 PM
safe depth to drain vinyl pool w/vinyl stairs
By ScottsdaleSwim in forum Testing and Adjusting Pool Water Chemistry
17
Last Post:
07-13-2006,
12:47 AM
Safe Swimming Chlorine Levels
By lizzie64 in forum Using Chlorine and Chlorinating Chemicals
4
Last Post:
06-26-2006,
09:00 PM
Safe shock PPM - vinyl pool
By falken in forum Using Chlorine and Chlorinating Chemicals
2
Last Post:
05-10-2006,
10:17 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
