Thread: Newbie needs help with 33 round rail/wall coming apart
    Aug 2011
    Default Newbie needs help with 33 round rail/wall coming apart
    33' round above ground pool.
    Liner is still locked in wall but wall popped out of the top rail after second load of water.
    Fitted liner and just installed.
    Pad, top and bottom within 3/8" all around.
    Default Re: Newbie needs help with 33 round rail/wall coming apart
    Hi and welcome to the Pool Forum. I am not a pool installer so can't really help with this but once your registration is complete and your post gets moved out into the general sections of the forum, one of our installers should be able to give you some advice. I just wanted to say hi and let you know that your post has been read and you aren't being ignored! Hope you enjoy the forum.
    just wanted to let you know you now have general forum access. -ben
  1. Replies: 1
    Last Post: 05-26-2013, 10:38 AM
  2. Fiberglass track "receiver bead" coming loose from the pool wall
    By steve789 in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2013, 05:00 PM
  3. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 04:24 PM
  4. Base Rail
    By rplj66 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2012, 03:12 PM
