Hi, and welcome to the forum!
You are right that most of your stabilizer probably went out with the water, but as far as granulated/liquid CYA, there's really no difference once it gets into the water--granular is no worse for SWCG than liquid. In fact, keeping an adequate amount of CYA in the water is important to help your unit's cell life...The SWCG gurus on this forum have said that keeping the CYA levels lower than your unit's manufacturer recommendations can actually shorten the cell life. Most SWCG's want 80-100 ppm of CYA, so you really need to check the manual for your unit and adjust yours accordingly.
It is normal for the pH to rise as a result of running the SWCG--that's because of the way it works. One of the products of the conversion from salt to chlorine is the release of hydrogen bubbles, which are acidic--and as they come to the surface and evaporate, your pool is losing acidity, therefore the pH is increasing. If you'll lower your TA to the 70-80 range, and then only add acid to drop the pH to 7.6, I think you'll find that your pH is a lot more stable and you won't have to use as much acid. You can lower your alk by this method; http://www.poolforum.com/pf2/showthread.php?t=191
There is really no need to shock the pool unless you're having an onset of cloudiness, see an excessive amount of chlorine use, or have a suspicion that there's a lot of goo in the pool that needs to be sanitized, i.e. lots of small kids, dogs, hurricane, etc (not that you have a lot of hurricanes in Ohio but we do get them down here in Louisiana!). One easy way to see if it needs to be shocked is if you test the chlorine at night after the sun is off the pool, and then test again in the morning before the sun hits the pool. If you lose more than 1 ppm of chlorine in that time, then the pool needs to be shocked. Also, if you test at any given point in the day and your CC is more than 1 ppm, then it's a good idea to shock. How high to take your chlorine level when you shock depends on your CYA level--here's the table: http://www.poolsolutions.com/gd/best...e-chart.html#a. I don't think it's necessary to turn the SWCG off when shocking with bleach--the worst case scenario is that you raise the chlorine a little higher than you intended, but that won't hurt anythig--it may just take a little longer for it to come back down to normal after the shock--it's really up to you. In a 19,800 gallon pool, each gallon of 6% bleach will raise the FC by 3 ppm, so you can use that as a guide to decide how much to add. Some people pour it directly into the skimmer, and some people pour it slowly into the return stream. Either way will help disperse the bleach into the pool. Just be careful not to splash on the side of the pool, or in your eyes or clothes. (Wear old clothes--even after 9 years of pouring bleach, I STILL splash it sometimes!). It's usually the most efficient if you'll add it at night, after all the swimmers are out of the pool, so that it has the whole night to work on goo in the water without interference from the sun.
Hope this helps!
