Thread: Repair PVC pipe?
    May 2010
    230 Gold Creek Court
    Default Repair PVC pipe?
    Hello everyone,
    Many thanks for the great info in this forum.
    Can anyone please help with the following? I have searched the forum and so far not found the specific answer.
    Our pool suddenly -- over 2-3 hours, anyway -- lost about 12" water down to the level of the Polaris supply pipe. The Polaris supply comes through a horizontal 5' x 2" PVC segment going level and straight out from the side of the pool to a 90 degree elbow. This entire pipe has been dug/exposed and the only apparent defect is not at a connector but is about 3-4 inches inside the mouth of the pipe at the plastic Polaris connector, a crack about 1/8 by 2 inches in upper wall of the pipe, within the portion of the PVC pipe that passes through the concrete of the pool wall.
    It looks like it's from shear stress as the underground segment of the pipe flexed and the concrete held the last few inches immobile.
    So, long back story...now a question: what's the best substance, like Permatex/Form a Gasket, Blue Glue, silicone sealant etc. to apply to the crack inside the PVC pipe that would plug the leak?
    I'd like to try the easy way first, before thinking about complete pipe replacement.
    Thanks!
    22,000 gallon IG Gunite pool
    DE screen-type Anthony VA-52 vertical filter
    Polaris automatic pool sweep
    BigDave's Avatar
    Default Re: Repair PVC pipe?
    Is the crack in the pipe or in the fitting for the Polaris connector?
    PVC is pretty straighforward to work with. A couple couplers, a length of pipe and some PVC primer/cleaner and glue can't be harder than trying to fill the crack with goo. You've already done the hard work digging it out, why not make a repair that will last? I suppose another option short of replacing the broken section of pipe would be a pipe repair patch or leak stop - I've seen these as a rubber cylinder (split to slip over/around pipe) with a steel band arounf the entire rubber cylinder and a couple band clamps aroung that - I doubt this would last long buried.
    May 2010
    Thank you for the reply. You're right, the correct fix usually is better than the quick fix...
    Can you recommend how to replace the segment of pipe that goes through the side of the pool, where it's encased by the concrete wall of the pool? Your guidance is much appreciated!
    Steve C.
    May 2010
    PS apologies -- forgot to provide the info you asked -- the crack is in the PVC pipe.
    As time passes, however, not sure whether the leak is at the flaw in the PVC pipe or at the union of the threaded Polaris connector and the PVC pipe.
    Thanks!
    Welcome to the Forum!
    Please answer BigDave's question. How thick is the wall and how far into the crete is the break?
  1. Broken Pipe Repair
    By Reese in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2012, 10:59 AM
  2. Buried Pipe
    By BigDave in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2011, 10:20 AM
  3. how to repair this pvc pipe problem
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 01-21-2007, 07:05 PM
  4. Pipe Leaking
    By robsp in forum Pool Equipment & Operations
    Last Post: 09-23-2006, 10:16 AM
  5. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2006, 11:19 PM
