Hi. I am new to this forum and really appreciate some help.
I have this pool for some years. last year, i have changed old DE filter to a new Hayward S244S pro series sand filter with 1hp hayward motor. I thought with this new filter I should have an easy season with this pool. Sadly, I got cloudy water from the very beginning. It just won't go away.
Tried several time with different clarify still have no difference. I have the water tested in different stores. They all points at those common parameters such as the Alkalinity, PH or Chlorine, even I don't see they have much difference with the test results I got in previous years. I had to buy tons of those to balance them, but the result is still the same, cloudy. The only thing that is low is calcium hardness which is at 50. I have a vinyl pool. Could it be a problem causing this cloudiness? Some store rep said it may be the cause of too much clarify. I am completely lost and running out options.
Could my filter is not set right or of no good? I never got such a problem with old DE filter. I usually add one bottle of clarify and immediately got crystal clear. Why would be so bad with this sand filter? I have no experience with this sand filter. Can the water be really cleaned with this filter? Really appreciate to get some help here. Hope can really swim once at least.
