Closed Thread
Thread: Pump size
    Ontario, Canada
    Default Pump size
    I am thinking about installing solar panels on my roof.
    (2 panels 2' by 20')
    The panels would be located about a 100' at a height of 10', could my 3/4 HP Hayward super pump handle this additional load?
    I am not sure as to what panels they will be since I am having a problem finding a supplier here in Canada.
    Any help would be very much appreciated.
    I.G. Pool 12' by 24' approx 10,000 gal, Hayward Sand Filter, 3/4 HP Hayward Super Pump.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump size
    Max head for that pump is around 55' which is more than enough lift to prime the lines. After, the lines are primed, the lift is no longer an issue. However, because of the pipe runs being 100' you should expect a significant increase in head loss and filter PSI rise. This is OK, it just means your flow will reduce and turnover rate increase so when running the solar, you may have to increase run time a bit.
    Mark
Closed Thread
  1. Pump Size?
    By Manny Cutes in forum Pool Equipment & Operations
    Last Post: 04-10-2011, 11:00 PM
  2. Pump Size
    By poolpup in forum Pool Equipment & Operations
    Last Post: 09-04-2006, 03:15 PM
  3. Pump Size
    By poolpup in forum In-Ground Pool Construction and Repair
    Last Post: 08-20-2006, 11:10 AM
  4. Need New Pump What size HP?
    By Joe44 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-31-2006, 10:07 PM
  5. Pump size
    By ssweaser in forum Above-Ground Pool Construction & Repair
    Last Post: 05-12-2006, 07:57 AM
