Basically, you need to add chlorine and stabilizer, (CYA). Each gallon of 6% bleach will add about 3ppm of FC. Since your water is now there sitting for a day, I would immediately raise the FC level to 10ppm -12pm. That's 3.5 to 4 gallons of bleach. If it's still that high when you want to swim wear old suits because they may bleach. Be sure to measure both FC and CC before you swim. CC should be 0 or no more than .5 ppm
You should aim to get an initial CYA level of 30ppm. I'd get 5 lbs to start. Read the label and calculate how many pounds of CYA you need to get 30ppm. Only add half that much. You'll need to wait 2 to 5 days for the CYA to show up on the CYA test in your kit. Don't test too often until you get refills for the test (I buy the reagent by the pint).
Be VERY wary of what they teach you in "pool school". I suspect EVERYTHING about pool chemistry is garbage. You'll know if they tell you the following:
1) you need calcium in your vinyl pool (you don't)
2) you need phosphate removers. (you don't)
3) Bleach is bad (it isn't)
4) Watch out for chlorine lock (there is no such thing)
5) Keep and use clarifiers, flocculents, and algaecides regularly. (You don't)
6) You need to shock weekly (you only shock when there's a need and a reason to shock).
Let us know how many of these they hit you with!
