Thread: Ever test the weight of your chemical containers?
    Jul 2011
    Boca Raton, FL
    Default Ever test the weight of your chemical containers?
    So following Waterbear's advice (given on another thread), I stopped by the nearby pool store to buy 4lbs of stabilizer. The shelf that had the stabilizer had a hand-written sign that said that if I brought back my container, I'd get a $2 refund (meaning, of course, that they've jacked up the price of the stabilzer $2 to motivate customers to return their containers). The price of the 4lbs of stabilzer was $14. I figured, then, that they probably refill those containers manually using a bulk supply in the back of the store.
    As I returned home, I thought that the container felt a little light for being a 4lbs container. So, once I got home, I got out our electronic postage scale and weighed the container. It weighed just 3lbs 10.6oz! After I dumped the contents into my pool, I re-weighed the container to see how heavy the container itself was: 3.7oz. So, I was actually gyped about a half-pound of stabilizer, which works out to about $2 worth of stabilzer.
    I'll bring this to their attention tomorrow when I take my water to be tested (perhaps for the last time at that store). But I wondered: Has anyone else found the net weight printed on a container of pool chemicals to be much greater than the amount of chemicals actually inside that container?
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Default Re: Ever test the weight of your chemcial containers?
    "I'll bring this to their attention tomorrow when I take my water to be tested (perhaps for the last time at that store)."
    "Gee, sir. You need $300.-- worth of chemicals!"
  1. Chemical Help
    By mreesept in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 01:58 PM
  2. Solar covers - 12 Mil vs 16 mil - weight an issue?
    By deckview in forum Pool Equipment & Operations
    Last Post: 06-06-2011, 04:55 PM
  3. weight vs. volume
    By purplegirl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2010, 11:51 AM
  4. weight of baking soda
    By ekaifes in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2008, 01:31 PM
  5. Weight down "wedding cake" ladder
    By cheriberi in forum Pool Equipment & Operations
    Last Post: 06-11-2007, 11:57 AM
