Thread: Heat Pump w/Chiller Cycle in Florida
    Jul 2011
    Default Heat Pump w/Chiller Cycle in Florida
    Looking to find info from folks who have performance history (in Florida) with a heat pump/chiller...which brands, performance expectations, etc. Thanks
    Ft Lauderdale, Fl
    Default Re: Heat Pump w/Chiller Cycle in Florida
    AquaCal.com is manufactured in St Petersburg, FL. We offer the IceBreaker model (heat and cool), and have thousands installed throughout the world.
    You would need to evaluate when you're looking to heat, or cool, and what temperatures; and most importantly, if you're willing to use a solar cover or not. The solar cover will help determine which size system (BTUs) you need.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    I've had an Aquacal Icebreaker reverse cycle model for several years now. Works great at both heating AND cooling ( but I rarely use the cooling feature since I like my pool WARM! However, the few times I did it really cooled the pool off quickly!) Main advantage for me with the reverse cycle is that it works well on the few nights of the year that temps drop into near freezing and freezing range in N. Fl. since it also heats my spa and those are the best nights for the spa! Standard heat pumps become useless below about 50 degrees ambient temp.
  1. Opinion: Gas heater and a Chiller or Heat Pump w/cooler?
    By poolgal13 in forum Pool Equipment & Operations
    Last Post: 04-05-2013, 02:03 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 07:37 PM
  3. Jandy Heat Pump W/ Chiller
    By beary in forum Pool Equipment & Operations
    Last Post: 06-23-2006, 02:57 PM
  4. Water cycle
    By crosso in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2006, 02:53 PM
  5. Timing the pump run cycle
    By kevincad in forum Pool Equipment & Operations
    Last Post: 04-11-2006, 06:32 PM
