Results 1 to 8 of 8
Thread: FIX A LEAK experiences
    Jul 2011
    Huntsville, AL
    Default FIX A LEAK experiences
    Am Considering using FIX A LEAK to correct a small 1/8"/day leak in excess of normal evaporation. Have there been any recent experiences on use of product.
    Honesdale PA
    Default Re: FIX A LEAK experiences
    Welcome to the forum.
    Don't think I ever saw it mentioned on this forum but can't be sure. I guess I'm skeptical how 1 quart of anything diluted in 20,000 gallons will do anything. Anyone have any comments and/or experience?
    Jul 2011
    Los Angeles, CA
    While I was away I got a call that my pool was leaking. My neighbor who lives on the hillside below me found water trickling into a puddle next to his house. We shut down the system and I came home early. By the time I got back all was dry. The leak didn't return until we started the system back up.
    We are in the middle of using Fix-A-Leak now. We don't know for sure where the leak is occurring. There's no air visible in the return, so logically we don't think its in the suction line, but it even so, just by looking it appears that the leak is probably at the bottom of the 50-year-old in-ground skimmer. Bubbles could be being filtered out at the pump if its a small leak. We're in the "hoping-it-works" phase, having run the system for about 2 and a half days and have now shut it off to let the Fix-A-Leak set.
    If it doesn't work I'll be trying to figure out a budget way to bypass the old skimmer.
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    I tried it this year for a leak I could not find. I would not waste my money on it. Made no difference.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Jul 2011
    Los Angeles, CA
    So far not working here either.
    Jul 2011
    Huntsville, AL
    Thanks folks. I too have been in the hope it works school, but the more I find out the more skeptical I get. Our summer has been high temp and high humidity with evaporation rates close to 1/2"/day. I guess that the small amount I'm having may well be just evaporation or measuring error.
    ralph
    I don't think 1/2" daily is excessive, in the kind of heat we're having this summer. Have you tried the bucket test? Put some of the pool water in a bucket, set it on the step, mark the levels of water in the pool and in the bucket, then check again the next day--if the pool level dropped further than the level in the bucket, then it's not evaporation...
    Jul 2011
    Huntsville, AL
    Thanks Janet- I did do the bucket test early on and the results were identical. That's my dilemma. I think I'll just go with the loss until (or if) it gets larger.
    thanks to all for your posts.
    Ralph
  1. Robotic Vacs for IG Pool- Good and Bad Experiences Please
    By myLABSpool in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-17-2010, 12:50 PM
  2. Solar heater experiences?
    By justinharlow in forum Above-Ground Pool Construction & Repair
    Last Post: 05-22-2008, 07:10 PM
  3. Leak help
    By chip85 in forum Pool Equipment & Operations
    Last Post: 03-25-2008, 05:52 PM
  4. Gorilla Pad -- experiences?
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 05-21-2007, 12:41 AM
