Thread: fixing pool leak?
    Default fixing pool leak?
    Hi,
    I turned on our aux pump for the polaris today and a geyser bubbled up from underground about five yards from the pool. Is this something I can fix myself? it's an inground pool.
    tia,
    jd
    Honesdale PA
    Default Re: fixing pool leak?
    I guess the good thing is you know you have a major leak as opposed to a dribble which you may not know about. Seems like the ground probably shifted and broke a pipe. Plain old muscle is needed to dig to the break assuming it's not buried in concrete. Once you locate the break, fixing it should be easy. If the pipe is PVC it probably broke. If it's the somewhat flexible black poly then maybe a connection popped loose.
  1. Fixing Cloudy Swimming Pool Water
    By PoolDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-07-2012, 11:13 AM
  2. Fixing alkalinity with the BBB method in Texas
    By RossM in forum Dealing with Alkalinity and Calcium
    Last Post: 06-06-2011, 10:13 PM
  3. Fixing liner pull-out from channel?
    By dbursch in forum In-Ground Pool Construction and Repair
    Last Post: 08-11-2009, 03:40 PM
  4. Fixing Wrinkles
    By jrv331 in forum In-Ground Pool Construction and Repair
    Last Post: 05-01-2008, 08:19 PM
  5. Fixing my swamp
    By jtnaylor in forum Dealing with Algae & Slime
    Last Post: 03-17-2008, 04:42 PM
