Thread: Aqua logic installation
    RAP is offline ** No working email address ** RAP 0
    Default Aqua logic installation
    Does anyone have an idea of the cost to purchase and install the Aqua Logic PS-4 in an exsisting pool?
    Severn, MD
    Default Re: Aqua logic installation
    About the only part I can help you with is the cost of the PS-4 itself. The lowest I've seen it online with the chlorinator is a little over $1000. You will also need to have someone come out and run the electricity for it as well as someone to do the plumbing (adding the salt cell and flow switch to your return lines after the filter). Because those can vary by location, I wouldn't even have a clue as to what it would cost for you. Unless, of course, you can do that yourself. You should also factor in the cost of the salt and I highly suggest getting a good water testkit that includes a salt test, if you don't already have one. I don't know how large your pool is, so I can't extrapolate that cost for you, but a good testkit (like Ben's offered on Poolsolutions.com) will run you $76 if you've not ordered a kit before and are not in a hurry for it.
    Hope this helps.
    Regards,
    Mark
  1. My pro logic panel
    By waxhaw in forum Pool Electronics
    Last Post: 08-01-2012, 11:06 AM
  2. Aqua logic false "low temperature"
    By desoto in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-22-2011, 07:49 PM
  3. Aqua Logic Controller not responding
    By desalvsj in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-31-2010, 10:42 PM
  4. Aqua Logic
    By HAYMAN in forum Pool Equipment & Operations
    Last Post: 05-01-2006, 09:20 PM
