Results 1 to 10 of 36
Thread: Sudden cloudiness
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Sudden cloudiness
    I went in the pool last night and it was perfect, I had a mask on and I could see from one end of the pool to the other, clear as day.
    The filter was off during the night, we have been having 90 degree weather lately.
    I got up this morning and the pool still looked great at 8am.
    I started the filter, and mixed up some shock and algaeside and dumped it into the pool and then added a little "quick clear"..Just to stay ahead of the warmth and algae.
    Then almost immediately the pool went cloudy...I went to work figureing it was from all the chemicals and that it would clear up in a couple of hours.
    My wife called at 5pm and said the pool was still cloudy.
    What could cause this???
    I plan on running the filter all night tonight to see if it will clear, but could something be wrong with my filter??/ (sand filter) It has been running with no problem lately.
    Or is it that I put to much chemicals in and it will take awhile, I put in half a scoop of chorine, probably 4-5 oz of the algaecide, 2 oz of "quick clear" and a little shock.
    Any suggestions
    thanks
    Barry
    Default Re: Sudden cloudiness
    The only thing needed to stay ahead of the algae is adequate chlorine levels. What kind of algaecide was it? What is the ingredient of "quick clear" and the chlorine you added?
    Post a full set of current water testing results taken with a drops-based kit. Tell us the type of pool and volume. Don't add any more "stuff" to the pool. Run the pump 24/7 and backwash if the pressure rises 5-10 psi over your clean filter pressure.
    Since, I wasn't going to be around for 3 days due to working 14 hours per day, I decided to take the proactive approach. I've had too many times that I didn't put chemicals in for three days and came back to green ring around the bottom of my pool. And add in the 90-105 degree temps these past days, I did not want to chance the algae build up.
    "if not broke don't fix it"...that approach don't work well with pools, it called upkeep not trying to catch up with an algae problem.
    I'm sure once I run the chemicals thru for a while it will clear up, like it has in the past...but thanks for your colorful comments and great suggestions
    Barry,
    I don't think anyone gave "colorful comments." In fact, in post #2 above, I asked you for some information so that I could try and help you straighten this out. If you would like to give the requested information, we will be glad to help you with this.
    Have you read any at our sister site www.poolsolutions.com? If not, you might take some time to do so. There is lots of good information there about basic pool maintenance that might be helpful for you. Also, read the BBB Method of Swimming Pool Care in my signature below.
    Again, we will be happy to help you if you like.
    Watermom,
    It appears to be clearing out, since running the filter over night, I think I just put too much chemicals in.
    But here are the chemicals I use:
    Quick Clear
    1200 Corporate Dr.
    Burlington, ON L7L 5R6
    Canada
    ACCU 50 Algaecide
    95 Hathaway Center
    Providence, RI 02907
    Active ingredients:
    n-Alkyl (60%C14, 30%C16, 5%C12, 5%C18)
    dimethyl benzyl
    ammonium chloride........................................49 .8%
    n-Dialkyl (60%C14, 30%C16, 5%C12, 5%C18)
    methyl benzyl
    ammonium chloride......................................0.2%
    INERT ingredients....................................... ..50%
    SUPER SHOCK
    109 King Philip Rd
    East Providence, RI 02916
    Active ingredients:
    Sodium Hypochorite.....................12.5%
    Inert Ingredients.............................87.5%
    Barry
    The algaecide, being ammonia-based, will break down into several byproducts, ammonia included. The ammonia in itself can create a high chlorine demand, taking some of your useable chlorine away from its normal job of killing algae. That's why the only algaecide that we recommend here is polyquat 60, which is NOT ammonia based, and also works as a clarifier (same as your quick clear). Sounds to me like you had an algae bloom trying to happen. If so, the shock and algaecide that you added may have stopped it for now, but it won't for long.
    If you could please post the test results that Watermom asked for above, it would help us help you to figure out what happened, and how to have it not happen again.
  1. The Dreaded Cloudiness!
    By dcsharpe in forum Pool Equipment & Operations
    Last Post: 05-14-2011, 06:48 PM
  2. Sudden pH drop...Why?
    By isdsms in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2008, 11:17 PM
  3. Neighbor has cloudy pool after 10 days of BBB, sudden dip in pH, TC
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-27-2006, 01:50 PM
  4. Sudden cloudiness?
    By Andy Fermaints in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-09-2006, 10:28 AM
  5. please help with cloudiness
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 10:08 PM
