These values work well, minimize pH rise, and keep the water balanced as well in case you have a plaster pool:
FC 4-5 ppm
pH 7.6 (and not lower) to 7.8 (when pH hits 7.8 lower it to 7.6)
TA 70 ppm
CH 350 to 450
CYA 75, 80 or 100 ppm (whichever is the manufacturers maximum recommendation for your SWCG)
Salt, depends on the make of your SWCG. some are 3000, some 3200, some as high as 6000 ppm. It is generally better to run the salt a bit high (by maybe 200 pm rather than a bit low in terms of cell life (but not so high that the high salt shutoff kicks on if so equipped.)
Borates 50 ppm (optional but highly recommended. If you don't add borates then either keep the calcium at the lower end of the range, run the salt a few hundered PPM lower or keep the pH slightly higher to keep the water balanced)
If you would like a more detailed explanation of WHY they work well let me know and I will be glad to post it but I warn you it gets a bit technical.
