Results 11 to 12 of 12
Thread: Pool cooling in muggy se missouri
    Default Re: Pool cooling in muggy se missouri
    The complication is calculating theoretical thermal loss through the things, because you have to consider things like panel emissivity, conductivity, and the sky's absorptivity (high on clear nights, low on cloudy humid ones).
    When you've used yours for cooling have you ever compared influent and effluent temps. (If your pool is hot enough, a fever therm might work!)
    Nah...I just run 'em in the cooler night air. I've forgotten what the solar panel formula is... something like your panels should have half the surface area of your pool. 'Way more than you actually need. I have the equivalent of the 3 4'x20' panels, and the "Rule" says I'm short by one...no way! Since all you are doing is warming pool water, tight tolerances on things like panel size, flow rates, critical BTU/Calories gen'd aren't really important.
  1. cooling the pool in Phoenix
    By hikernut in forum Pool Equipment & Operations
    Last Post: 05-17-2012, 06:54 PM
  2. Pool water cooling
    By mshumack in forum Pool Equipment & Operations
    Last Post: 08-21-2010, 11:18 PM
  3. Cooling a Hot Pool
    By rlanthony@excite.com in forum Pool Equipment & Operations
    Last Post: 09-03-2007, 12:26 PM
  4. Intex Pump Cooling
    By Bob R in forum Pool Equipment & Operations
    Last Post: 07-21-2006, 12:43 AM
  5. Cooling with solar panels?
    By mkelley in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 11:28 AM
