Thread: Using Chlorine
    Jun 2011
    Default Re: Using Chlorine
    i shocked last night broght fc to 17.5 ppm. i checked this morning. cc-0 fc-16.5 and my ph went up its at 8.0 which is as high as my taylor 2006 kit will register. is it normal for ph to go up when using about 1.75-2.0 gal bleach?
    Taylor K-2006 -- ~14k gal. 24 ft x 52" AG
    Meteor 20" Sand Filter Pentair 1.5 hp pump
    Retest pH when the chlorine comes down. If you test while the chlorine is high (above 15ppm for a K-2006 I believe), you get a falsely high pH reading.
    BTW -- Add a little info to your signature for us please. (volume, kind and size of filter, and the fact that you have a K-2006)
    Thanks!
    Jun 2011
    since there was no CC readings this morning should i continue to keep at shock level?
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 09:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 07:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 05:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 10:53 PM
