Thread: Didn't know I'd be able to taste the salt.
    Default Didn't know I'd be able to taste the salt.
    Is this normal? I added about 8 bags to a 20k pool, that's when the add salt light went off.
    Indiana.
    Default Re: Didn't know I'd be able to taste the salt.
    You can't really rely on that light to be very accurate unless you've verified it with a test kit. Take a sample to a pool store for a reading. You added almost 2000ppm of salt if they were 40lb bags. Unless there was already salt in there, you shouldn't be tasting it.
    Katy, TX
    At 3200 ppm, i can tell there's something in there. Its not real strong though. I'd check your results with a test kit to be sure.
    Michael
    Dec 2005
    South Carolina
    tbkp,
    I keep 3200 ppm in my pool. Last weekend several people who'd never been in a saltwater pool went for a dip (didn't know about the salt in the water). Afterwords, 2 of the 5 said they tasted a VERY slight saltiness, the other 3 had no idea.
    I can taste it for just a second, then goes away.
    Bottom line, you need a good drop based test via Ben or Taylor (you can order online). Don't rely on the light or the readout.
    Nater
    p.p.h. is offline ** No working email address ** p.p.h. 0
    Dec 2005
    Phoenix, AZ, usa.
    im at 4,000ppm and its a light salty taste. the feel of the water makes me forget about it though.
    Keep mine at about 3400 ppm and can't taste the salt....then again I also live about a block from the ocean and swim there also so maybe I'm more used to seawater so I don't notice low salt levels.
  1. Raise borates to 50 ppm but didn't see any corresponding increase in alk
    By Dead Beaver Ranch in forum Dealing with Algae & Slime
    Last Post: 03-31-2013, 01:13 AM
  2. Salty Taste?
    By ds_girl in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-16-2007, 03:30 PM
  3. pool didn't go up today....
    By Trimom in forum Above-Ground Pool Construction & Repair
    Last Post: 07-26-2006, 03:07 PM
  4. I hope I didn't turn my pool into the Love Canal....
    By CrazyJoey in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-14-2006, 01:21 PM
  5. Added DE to Sand Filter, 1 cup didn't raise PSi
    Last Post: 06-29-2006, 12:39 AM
