Thread: high chlorine, but crystal clear!
    Jun 2011
    North Texas
    Smile high chlorine, but crystal clear!
    This is my first time to post, but after studying your BBB method my pool has gone from green to crystal clear! I started using bleach from grocery store, but I continued using the trichlor tabs in skimmer (my bad). I received the TAYLOR kit, and got the reading of high chlorine. I quit using the trichlor tabs two days ago.
    But, I am worried about high chlorine level of 17.
    FC: 17
    Total C: 0
    PH: 7.2
    Alk: 75
    CYA: 80
    I tested for calcium, but the TAYLOR kit did not turn red, just pink. But, I still did the next steps and reading was 120.
    Vinyl liner, 26000
    Thank you!
    Default Re: high chlorine, but crystal clear!
    Hi Katydid and welcome to the Pool Forum! Thanks for becoming a subscriber. That is awesome. We appreciate the support of those who pay for subscriptions because it helps keep the forum online.
    Don't worry about the FC of 17. It will come down on its own and it's not that big of a deal. Pools with high CYA can run higher chlorine levels. If you haven't already done so, take a look at the Best Guess chart in my signature below. By the way, FC + CC = TC so your numbers above are not reported quite right.
    Keep an eye on your pH. It is ok at 7.2 but if it goes lower, you'll want to bump it up a little with some Borax.
    Hope you enjoy being a part of the forum. We are glad you found us!
    Jun 2011
    North Texas
    Watermom,
    Thank you for the info. I didn't know about the FC + CC = TC. How much Borax should I add to increase PH ? On my previous post, I stated vinyl liner, 26000 K, but my husband informed me the pool was 27,500 K. Your forum is awesome!
    Jun 2011
    North Texas
    Watermom,
    I found the Borax info. on your Pool Solutions: I added 2 cups through skimmer, and I will check PH in 24 hours.
    Thanks again!
  1. Zero FC Pool is crystal clear
    By Hurricane1938 in forum Dealing with Algae & Slime
    Last Post: 08-29-2012, 01:48 PM
  2. best approach to crystal clear water
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-20-2012, 05:15 PM
  3. CYA/crystal clear green water
    By purplegirl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2010, 10:46 PM
  4. Not crystal clear.. I want it crystal clear.
    By chuck9997 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2010, 10:56 AM
  5. Crystal clear water but all figures a bit off.
    By Guido in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2006, 01:45 PM
