Thread: Unfloating the liner for leak check.
    Jul 2011
    Southern Maine
    Default Re: Unfloating the liner for leak check.
    I put electrical tape over the holes last night and left the liner nice and tight ... its floating again this morning ... I'll have to keep looking.
    Its a June-2001 pool/liner.
    I also found a hole in the fiber line that runs the perimeter of the coping ... got water in there too half way around the pool. It makes the light look choppy. I'll have to figure out how to suck that water out and seal it up then pray it doesn't algae up ... the stuff is over $3/foot. Sigh.
    Is there any safe way to stay under the water and still breath using home available materials?
    ~18,000g; 16' x 32' IG; Vinyl; 1HP x 36sq-ft Hayward DE; Solar Attic PCS2 Heat; G25 Nature2; New Water 400; Fiber Stars 8-Color Perimeter and Wall; Clear Cover
    Jul 2011
    Southern Maine
    Found a 3/4" rip on the bottom of the shallow end last night .... it had pretty good suction on it too.
  1. How to check for DE filter "leak"?
    By jkmhb in forum Pool Equipment & Operations
    Last Post: 06-24-2011, 07:56 PM
  2. Leak in liner?
    By AnnaK in forum Above-Ground Pool Construction & Repair
    Last Post: 04-16-2010, 07:40 PM
  3. Liner leak
    By elsie in forum Pool Equipment & Operations
    Last Post: 03-13-2007, 12:13 PM
  4. Another liner leak
    By mhnewcomb in forum In-Ground Pool Construction and Repair
    Last Post: 06-23-2006, 09:38 AM
  5. New Doughboy with liner leak
    By sartail in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2006, 09:28 PM
