Re: Combine SWCG and Tri-Chlor Floatie?
Depends on some factors you have not considered. Main cause of rising pH in a salt pool is from outgassing of CO2, which is easily controlled by dropping TA.
As far as CYA decreasing, not all pools will have that problem since not all pools have backwashing filters. For example, my salt pool with cartridge filter, needs to have salt, CYA and borates added about once a year since I lose very little and my levels remain very stable. With my TA at 70 ppm and borates at 50 ppm my acid demand is about a cup every two months, not a whole lot at all. Pool is open year round, btw.
If I started using trichlor in my pool I would need to increase the TA on a regular basis to compensate for the TA that is getting 'used up' by the acidic trichlor and my CYA would soon rise way too high so for me this is not a valid solution.
If someone has new plaster that is adding the the pool's acid demand then I can see a limited usefulness of trichlor but from my experience with customer's pools the speed at which CYA is added is usually much faster than the speed at which it is removed from backwashing and splashout. If the pool was leaking water then this approach might be more useful. I have found that customers with sand filters usually need to bump of the CYA and salt a abut 3 times a year, still not a lot.
