Re: New Here. Going to Salt???
One other thought. The Jandy user manual says the controller is supposed to be installed a minimum of 5' off the ground. The electrian who installed my Jandy SWCG put the controller only 3' off the ground. Not sure why that matters, really, except that being lower to the ground, there's a greater chance of having rain water hit the controller, or having my lawn's sprinkler system hit the controller. When you have them do the install, be sure to tell them you want the controller installed 5' off the ground.
South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
