Thread: Using a heater with a small (barbecue) propane tank?
    Berwyn, PA
    Question Using a heater with a small (barbecue) propane tank?
    Our pool heater was connected to a large (120 gallon?) propane tank, but we only used it a few times a season (just for heating the attached spa, not for the big pool) and couldn't justify the tank rental fees.
    I was wondering if I could adapt the small propane tanks (the kind you get at Home Depot et al) for occasional heater usage. Any pointers to technical issues I might need to research (pressure levels, regulator, connectors) would be appreciated.
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    May 2010
    Default Re: Using a heater with a small (barbecue) propane tank?
    A 4 gallon tank could heat a 11,000 gallon pool just 4 degrees F. How often would you like to change the tank?
    Largo, Florida
    I'm sure you could, but you might want to find a book on the subject or something. There may be different pressures and things that need to be adapted. I did the opposite; had the gas company run a line from my rented 120gal tank to my propane grill rather than filling the 5gal tanks.
  1. Questions about a new propane heater.
    By smacd in forum Pool Equipment & Operations
    Last Post: 05-27-2011, 03:04 PM
  2. Need propane heater recommendation
    By DanS in forum Pool Equipment & Operations
    Last Post: 08-15-2009, 11:57 AM
  3. propane heater replacement
    By vinouspleasure in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2008, 11:58 PM
  4. Heat pump vs Propane Heater
    By mmcguire in forum Pool Equipment & Operations
    Last Post: 07-27-2006, 03:14 PM
