Thread: Small 1 inch rip in bottom of pool HELP
    May 2010
    20 alexandria drive
    Default Small 1 inch rip in bottom of pool HELP
    My son just found a small rip in bottom of pool. We have notice it has gone down a bit recently. Can this be fixed without draining pool? I heard of Boxer glue any ideas?
    Vicki
    Default Re: Small 1 inch rip in bottom of pool HELP
    Yes, boxer glue 100 is what you want and you are right that you do not need to drain the pool to patch it. When we found a couple of small rocks under my liner a year after it was installed (it apparently was in the sand and took awhile to work its way up to the liner) we put a patch on so that if it did rip through the liner at some point, it wouldn't leak. We took a small piece of leftover liner and patched it. It has held for about 4 years now. It is a little discolored (I think from the glue) but it has not come up any even on the edges.
    May 2010
    20 alexandria drive
    Ok thanks so much I will see if the pool store has some tomorrow!!! Hoping we have extra liner. Thanks
    If you need help with how to apply a patch, I'll be around Tues. PM and Wed. (I'm gonna try to get my patching info typed up and posted on one of those days )
    I'll also be here to check in tomorrow.
    Honesdale PA
    Haven't been around for a bit and just getting around to catching up on the forum. Boxer 100 is a slow acting cement. The stuff that normally comes with the patch kits I've tried will attack the vinyl and curl it real fast so you have to get it in place fast. I did a deep end patch years ago and it's still holding. Took time to place it, squeegie it, then drop a sandbag on it so I needed the slow acting stuff.
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 04:53 PM
  2. Replies: 0
    Last Post: 12-24-2012, 04:16 PM
  3. Intex 12 ft by 30 inch pool
    By TiffanyMcEwan in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-28-2012, 11:19 PM
  4. Does anyone here have a 54 inch high pool?
    By daltrey in forum Above-Ground Pool Construction & Repair
    Last Post: 08-08-2006, 11:25 AM
