Results 1 to 10 of 37
Thread: New to this Forum from SoCal
    Default Re: New to this Forum from SoCal
    You'll need a better test kit to make it easier to keep this pool clear. The one we recommend is the Taylor K-2006 or 2006C (same kit, larger bottle of some reagents). If you buy it through the Amazon link in my signature, the Pool Forum makes a little money on the sale which helps us keep this form online. Only buy if the seller is Amato Industries, however. Some other sellers are substituting the K-2005 which you do NOT want. If Amato isn't listed, wait a day or two and try again. They seem to restock pretty quickly when they sell out.
    In the meantime, can you take a water sample to a reputable pool store and ask them to test for you and report your numbers here? Make sure that two of the readings they give you are CC and CYA in addition to FC, TC, pH, TA. But, don't let them talk you into buying a bunch of stuff. They'll try!
    Repost with some good numbers and somebody here can help. I would wait on the creeper since you say it is throwing green water back out. Lets work on killing the algae first.
    Jul 2011
    SoCal
    OK. i just had the water tested at the pool store.
    TA=110
    PH=7.2
    CYA=30
    TH=340
    TC=7.7
    FC=7.7
    CC=??? they didn't have a test for this but said it was 0
    salt=3800
    The pool store didn't try to sell me anything and said to just keep cleaning the filters and run the creeper. But, i will wait on the creeper because this forum seems to have more knowlege.
    A question --- when you say 10lbs. chlorine, is this liquid or granular, and what is the ingredient? I'm suspecting cal-hypo because of your calcium hardness reading of 340.
    Jul 2011
    SoCal
    sorry, i meant 10 gallons of chlorine from Lowes. Lable reads: 10% sodium hypochlorite, 90% inert ingrediants, available chlorine 10%.
    Let's try shocking the pool up to about 12ppm this evening when the sun is off the pool. Then, test it again in the morning within 2 hours of sunrise and let's see how much chlorine you are losing overnight. If you lose more than 1ppm of cl overnight, that will tell us that the algae is not dead. Report back here tomorrow with your results. Run your pump 24/7 and clean the filter as necessary.
    Until you can get a good kit like I suggested above (you need one!!) go to Walmart and pick up a cheap OTO/Phenol Red kit. (The one with the yellow and red drops.) That will be better than the strips. The OTO kit will only measure chlorine up to 5, but you can force it to go higher with a dilution method described here: Testing Without a Good Kit
    Your TA is good, pH is ok at 7.2 but don't let it drop any lower. If it does, you'll need to bump it up a little with some 20 Mule Team Borax (laundry aisle at Walmart.) In fact, while you are buying the OTO kit, go ahead and pick up a couple boxes of Borax while you're there to have on hand. Your TH is ok but you don't really want it any higher, so no cal-hypo for this pool.
    Report back tomorrow with the results of the overnight test.
    Hope this helps.
    Jul 2011
    SoCal
    Great. thanks for the advice. is there a specific brand of shock that you could recommend or is it all the same? How much would you think i need?
    I will order the good kit as you stated.
    Thanks again.
    Sorry I didn't get back to you after you posted again. I spent the evening in my own pool.
    It isn't necessary to buy "shock." Shocking the pool just means giving it a hefty dose of chlorine. Just use the 10% sodium hypochlorite that you already have on hand. In your pool, each quart of the 10% chlorine will add 1ppm. When you test, add enough to get back to 12ppm. Do this for a day or so and see if you are losing any overnight.
    Keep us posted!
  1. new to forum
    By outlawjess6 in forum --cleanup--
    Last Post: 12-04-2012, 08:26 AM
  2. New guy to the forum but always appreciate. . . . .
    By Pool Deacon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2011, 11:19 AM
  3. First pool in socal--what to do?
    By noworries in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-29-2006, 06:57 PM
  4. Solar cover worth it in Socal?
    By noworries in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 10:01 PM
  5. Solar heating in winter in Socal?
    Last Post: 07-20-2006, 06:03 PM
