Results 11 to 20 of 25
Thread: Solar Cover Reel
    Default Re: Solar Cover Reel
    As long as my return jet is aimed downward, it does not move the cover. If it is aimed at the surface of the water where I would normally keep it to push floating debris into the skimmer, then it does push the cover.
    Jul 2012
    Illinois
    I have the same size pool as you did then. Do you remember how long each pipe was? Thanks!
    Just moved in so I'm not exactly sure on manufacturers or specs; best guess: 24' x 48" AGP, sand filter with 3/4HP pump, Taylor K-2006
    Each of the pieces of pvc was 10 feet long.
    This thread is a few years old. There is actually another thread started this week where someone was asking the same question ----- how to manage a large round solar cover on an AG pool.
    I used the system explained in this thread for quite a few years and it worked well. But, last year, I ran across a product called a Solar Roller Cover Stick that I now use instead. Here is a link to the product in case someone missed that other thread and is interested in this product.
    http://www.solarroller.com/
    Bumping this up so one of our new members can find it easier.
  6. #16
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Where did you get your cover from? Also, the mil of the cover?
    Getting so excited to swim and play in our pool.
  7. #17
    I got it from Lowe's. I have no idea what the mil is. I think this is my third year with this one.
  8. #18
    Jun 2014
    A northeast state
    What great idea! I bought a solar cover for my 15x30 oval AG pool. Have used it once because it is such a bear. I guess this would work for my cover too. Going to try it!
    Quote Originally Posted by Scrapple View Post
    Which idea are you referring to? There are a couple of different ones in this thread.
  10. #20
    Jun 2014
    A northeast state
    All of them
  1. Solar cover reel
    By Maacjones in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 02:05 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  3. Solar cover reel
    By mikepens in forum Pool Equipment & Operations
    Last Post: 07-03-2008, 09:37 AM
  4. Solar Cover Reel
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-13-2007, 03:40 PM
  5. Solar cover reel
    By Prov35 in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 01:07 PM
